MDM0
Apr 18, 2020Aspirant
Ping spikes on wired connection.... HELP identify problem
Hello - I am experiencing random ping spikes on games such as CSGO for what seems like no apparent reason. I have checked and verified that all drivers are up to date both for the router an...
Apr 20, 2020Guru - Experienced User
I would use pingplotter.com with a wired PC connected to the ISP Modem/ONT first. Then test same app with the router in the mix.
Please post about this here for your model router:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
You might try Voxels 3rd party FW as well.
Good Luck.
MDM0 wrote:Hello -
I have checked and verified that all drivers are up to date both for the router and PC. The current connection I have is wired 150/10.
Can someone tell me how to check where the problem is coming from or a fix?
Thank you
- kovachularApr 20, 2020Aspirant
That was really great advice for troubleshooting. I'll try this later and give it a shot.
Any other network tools you recommend? I've been looking for tools like this for a while.
- MDM0Apr 20, 2020Aspirant
Thank you for the response.
The Modem I am currently using is Technicolor Model:TC4400-AM.
When I am using pingplotter should I be entering a website address or some type of IP for the program (ie. Counter Strike CSGO) which i am experiencing issues on? Evereything else appears to be working as normal as I have run many speed tests and I am also always near the max of 150/10.
- FURRYe38Apr 20, 2020Guru - Experienced User
Just ping out to pingplotter.com for direct with the modem. Once you add the RBR, you can ping to the routers IP address, then ping to the modems IP address on the LAN use, usually 192.168.100.1. You can ping the WAN IP address on the modems side as well.
Look for Packet Loss coloum. You many need to enable this column.
Ok, so i ran pingplotter for about 10 minutes to the following
-pingplotter.com
-192.168.1.1
-192.168.1.9
Im showing PL % at 27% for 192.168.1.1 on the pingplotter tab, however at the bottom (im guessing totals) its at 0.8. The other two tabs (192.168.1.1 and 192.168.1.9) are at about 1ms with zero packet loss. Please let me know if i should post any pictures as I am unsure which contain sensitive data.
Thanks
Also, as I was writting this the PL % for pingplotter seems to be going down as it is now at 20%, not sure if this has anything to do with it.
