MDM0
Apr 18, 2020Aspirant
Ping spikes on wired connection.... HELP identify problem
Hello - I am experiencing random ping spikes on games such as CSGO for what seems like no apparent reason. I have checked and verified that all drivers are up to date both for the router an...
Apr 20, 2020Guru - Experienced User
I would use pingplotter.com with a wired PC connected to the ISP Modem/ONT first. Then test same app with the router in the mix.
Please post about this here for your model router:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
You might try Voxels 3rd party FW as well.
Good Luck.
MDM0 wrote:Hello -
I have checked and verified that all drivers are up to date both for the router and PC. The current connection I have is wired 150/10.
Can someone tell me how to check where the problem is coming from or a fix?
Thank you
kovachular
Apr 20, 2020Aspirant
That was really great advice for troubleshooting. I'll try this later and give it a shot.
Any other network tools you recommend? I've been looking for tools like this for a while.
