jteagles
Nov 21, 2018Tutor
Playstation Network problem
Evening all,
Last night got my XR500 working (internet speeds are showing as slower than my isp router but thats for another thread) and tonight Ive put the PS4 on for the first time since using t...
Netduma-Fraser
Nov 21, 2018NetDuma Partner
That's strange. I've had it occur sometimes when you have to go to settings and login to PSN first, does that work?
jteagles
Nov 21, 2018Tutor
Thanks for the reply mate,
No that doesnt work.Also I can login no problem through the iphone app
*update* I just tried to set up a wirless connection to the PS4 and the PSN sign in failed on that too.
- Netduma-FraserNov 21, 2018NetDuma PartnerDo you have the Geo-Filter enabled? If so disable and try again, does that work? If not try directly connected to the modem/router instead of the XR500 does it work then?
- jteaglesNov 21, 2018Tutor
Netduma-Fraser wrote:
Do you have the Geo-Filter enabled? If so disable and try again, does that work? If not try directly connected to the modem/router instead of the XR500 does it work then?Just removed the ps4 device from the geo filter but that didnt work.I have the modem set as modem only, will it still work if I connect the ps4 straight into that ?
- Netduma-FraserNov 21, 2018NetDuma PartnerYes it will, please try and see what happens
