Matt_007
Mar 29, 2019Tutor
PlayStation remote play issues with XR500 router
I have been given an XR500 nighthawk from a friend as I was thinking of buying a x10 but since changing I can't use remote play anymore from out side connection.. I seen an answer to problem on her ...
- Jun 14, 2019I have now fixed issued yesterday I purchased a dm200 router/modem run in modem mode got username and password from Vodafone and everything works, and the net is 10x faster in general..
Just unfortunately the psn servers went down last night so after hours of messing about with router found out I was wasting my time đ
Matt_007
Apr 01, 2019Tutor
Hi and thanks for the reply the firmware is v2. 3.2.40 and updated when I set it up.
I used the set up wizard to get the router working. And then put the Vodafone router into modem mode as per Vodafone tech support advised me. They also gave me network username/password if I needed.
The DMZ server I have set up I have put the Ps4 ip into.
Netduma_Jack
Apr 02, 2019NetDuma Partner
Also make sure UPNP is enabled on your XR500. Also port forward 9295 (for TCP), and 9296 and 9297 (for UDP) to your PS4's IP address and see if that works.
- Matt_007Apr 02, 2019TutorThanks for your response
Yeah that is switched on,
Port forwarding, is that in the actual port forwarding section create one for ps4 ip address?
