Matt_007
Mar 29, 2019Tutor
PlayStation remote play issues with XR500 router
I have been given an XR500 nighthawk from a friend as I was thinking of buying a x10 but since changing I can't use remote play anymore from out side connection.. I seen an answer to problem on her ...
- Jun 14, 2019I have now fixed issued yesterday I purchased a dm200 router/modem run in modem mode got username and password from Vodafone and everything works, and the net is 10x faster in general..
Just unfortunately the psn servers went down last night so after hours of messing about with router found out I was wasting my time đ
Apr 03, 2019Guru - Experienced User
If the modem IS fully bridged, DMZ is not needed on the router. Just uPnP.
What you might do is set the modem back to router mode. Connect the PS to the modem. Does it connect then? If so, reconnect the XR router to the modem. Keeping the modem in router mode. Then use the Modems DMZ for the IP address the XR router gets from the modem. Input this IP address into the modems DMZ. Connect the PS to the XR router. DO not put the PS IP address into the XR DMZ. I would reboot modem, router and power OFF the PS. Wait for the modem and router come back to ready. Power ON the PS and test.
Matt_007 wrote:
I have been given an XR500 nighthawk from a friend as I was thinking of buying a x10 but since changing I can't use remote play anymore from out side connection.. I seen an answer to problem on her to do a DMZ ip for PlayStation and this doesn't some the problem and could not reply to the thread, any ideas? But issue is annoying me and will go back to Vodafone router and not purchase an x10 if can't solve ...
- Matt_007Apr 06, 2019TutorI have gone back to original Vodafone router and works, then gone back to the NETGEAR and no connection, checked all ip address ect.. Other places I'm starting to see that it's the Vodafone router is the issue,
I have an old bt router and user name and password, but if its a 10 year old router will that effect the speed if its just in modem mode?- Netduma-FraserApr 06, 2019NetDuma PartnerAs long as it can handle your speeds it should be just fine to use the BT router.
- Matt_007Jun 14, 2019TutorI have now fixed issued yesterday I purchased a dm200 router/modem run in modem mode got username and password from Vodafone and everything works, and the net is 10x faster in general..
