Matt_007
Mar 29, 2019Tutor
PlayStation remote play issues with XR500 router
I have been given an XR500 nighthawk from a friend as I was thinking of buying a x10 but since changing I can't use remote play anymore from out side connection.. I seen an answer to problem on her ...
- Jun 14, 2019I have now fixed issued yesterday I purchased a dm200 router/modem run in modem mode got username and password from Vodafone and everything works, and the net is 10x faster in general..
Just unfortunately the psn servers went down last night so after hours of messing about with router found out I was wasting my time đ
Netduma-Fraser
Apr 06, 2019NetDuma Partner
As long as it can handle your speeds it should be just fine to use the BT router.
Matt_007
Jun 14, 2019Tutor
- Netduma_AlexJun 14, 2019NetDuma Partner
I'm glad you got it working.
Yeah I was trying to play online yesterday and nothing was working. If I had another console I would've whipped it out at that point.
