Mygamertagsucks
May 15, 2021Apprentice
Please Explain Like I'm 5 years old
I must be misunderstanding the QoS part of this operating system. My Internet is 500/25. I go into device manager first, and delete all of the things that are offline, and will be offline for awhile, ...
- May 15, 2021If you're just gaming on the PS4 it is impossible to be a bandwidth hog, gaming uses less than 1Mbps so you definitely don't need to be allocating that much to the console as it won't use it anyway. Anti-Bufferbloat is what keeps all devices from using the entirety of your connection by ensuring that bandwidth is kept in reserve meaning that you won't lag even if devices download etc.
Netduma-Fraser
May 15, 2021NetDuma Partner
