Mygamertagsucks
May 15, 2021Apprentice
Please Explain Like I'm 5 years old
I must be misunderstanding the QoS part of this operating system. My Internet is 500/25. I go into device manager first, and delete all of the things that are offline, and will be offline for awhile, ...
- May 15, 2021If you're just gaming on the PS4 it is impossible to be a bandwidth hog, gaming uses less than 1Mbps so you definitely don't need to be allocating that much to the console as it won't use it anyway. Anti-Bufferbloat is what keeps all devices from using the entirety of your connection by ensuring that bandwidth is kept in reserve meaning that you won't lag even if devices download etc.
Netduma-Fraser
May 15, 2021NetDuma Partner
Mygamertagsucks
Thank you for the reply, and explanation. I've always heard gaming uses a minute amount of bandwidth, but I somehow got it in my head that more is better, for everything.
Fortunately, after rereading your post, I now have a better understanding of the software, and kinda feel like a doink for not knowing any better.
- Netduma-FraserMay 16, 2021NetDuma PartnerDon't feel that way, it's actually quite a common misconception! Ping is the most important and higher speeds doesn't necessarily mean lower ping.
