usermac
Aug 17, 2018Luminary
Please FIX GEO FILTERING MODE PUBG :(
PUBG and the filtering mode is simply not working when matchmaking. I can not connect to any local server.
Its used to be when matchmaking it would skip putting me in servers out of my selected ar...
Netduma_Jack
Aug 17, 2018NetDuma Partner
Hi Mac - thank you for letting us know about this. It’s very likely that Blue Hole have changed their server setup given their whole ‘Fix PUBG’ campaign.
We will test this ASAP and push a cloud update out which should automatically correct the locations.
In the meantime, I recommend you switch to spectating mode and enable auto-ping. Then while you are in the lobby with the other 99 players, you can back out if the ping is too high.
Thanks again for bringing this to our attention.
usermac
Thanks for the advice I will use the spector for now.
- usermacSep 01, 2018Luminary
I dont want to moan and that but I do feel verry little is being done in order to get this GEO Filter working.
I have been using the spectator for about a month and am simply fed up with having to leave games due to high ping.
One in in ten matchces I will be lucky to get a london or france server instead I am put in high ping server and have to repeat process.
Is Netduma any closer in getting the GEO FILTERING working on PUBG
A cloud update is needed ASAP or some information on Netdum's progress in how they are getting on with tackling the issue's getting the Geo Filter working.
Host Type Peer
ID 1b5808d3f5bac5ca
Domain Name 58cabad3.setaptr.net- Netduma_JackSep 01, 2018NetDuma PartnerHi Mac - we are collecting as many server ids as we can so please could you let us know of them here:
http://forum.netduma.com/topic/25918-pubg-players-can-you-help/?tab=comments#comment-188173
Our own testing shows about 80% are correctly located. Where are the laggy servers typically located for you?- usermacSep 02, 2018LuminaryMostly seem to get get connect easy of Germany or going by the location located. My pings will be anything from 50 to 85
Some times I get France and that’s not so bad just the the fluctuation on ping start rubber banding all over the place. If I get London server my ping is great usually around 10ms and it stays at that. But getting a London server is quite time consuming to find. I am pleased you are 80% closer.
Should I just copy and paste the server info when I connect to a local one and post them on that link ?
