Netduma-Fraser
Dec 17, 2019NetDuma Partner
Please read if you're experiencing DumaOS not loading/login interface issues
We have received multiple reports about these issues. I have reported this to our team as this seems to be affecting a few people today, please follow these instructions provided as a workaround whil...
Starworshipper
Dec 17, 2019Initiate
Same issue, just chiming in.
Factory reset DID NOT work.
Downgrading the firmware DID work.
Time to spend a good hour or two resetting my configuration. Feelsbadman.
LevelUpLiam24
Dec 18, 2019Apprentice
Had the same problem this morning, I can confirm the solution.
Downgrading the firmware to V2.3.2.32 resolved the issue.
Remember to deactivate router auto firmware update if it's enabled.
Awaiting a fix for this issue. Thank you!
- Netduma-FraserDec 18, 2019NetDuma PartnerPlease see the post above yours for the link to the fix. Essentially if you re-upgrade back to .56 it should now work fine for you.
- LevelUpLiam24Dec 18, 2019Apprentice
Worked like a charm, everything is running correctly.
Thanks so much for calling that out can't believe I missed it.And thanks to the devs for addressing the issue!
Hope everyone at Duma has an awesome holiday!
- Netduma-FraserDec 18, 2019NetDuma PartnerGlad to hear that! Thank you, you too!
