mluca117
Jan 12, 2021Aspirant
Plex Media Server ReadyNas with XR700 Nighthawk Router
Hi there. I had a question in regards to my Nighthawk XR700 Gaming router and Plex Media Server. I just downloaded the new firmware update V1.0.1.36 onto my XR 700 router and did a factory reset, al...
michaelkenward
Jan 13, 2021Guru - Experienced User
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's impenetrable community structure.)
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Nighthawk Pro Gaming Routers - NETGEAR Communities
I will ask the Netgear moderator to move your message.
mluca117
Jan 13, 2021Aspirant
Thanks for the replies. I just posted it in the following link. Hopefully it reaches the correct community this time around!
