mluca117
Jan 14, 2021Aspirant
Plex Media Server ReadyNas with XR700 Nighthawk Router
Hi there. First off, sorry if this was posted in the wrong discussion. I reposted this from another discussion and hope this is the right spot for it now. That being said, I had a question in regar...
Netduma-Liam
Jan 14, 2021NetDuma Partner
Thanks for posting!
The Plex media server feature is not actually a part of DumaOS, but I'll do my best to help you anyway! Otherwise we may need to speak to a member of the Netgear team.
My thoughts so far are that because the XR700 does all the networking elements of the Plex server itself, adding a NAS will be doubling up on those features and therefore likely won't work. Do you have a regular external HDD that you can connect so we can narrow down the issue? I would expect you to see the same issues if you were to connect the MyCloud drive as this is also a NAS.
EDIT: Apologies, I've just seen your other post. I'll leave this here anyway but as Fraser mentioned in your other post, this may be something you'll need to discuss with Netgear using the link he provided!
