WacoJohn
Apr 09, 2019Luminary
Polk Audio, Google Home, XR500
I have a Polk Audio MagniFi Mini Home Theater Sound Bar System which is supposed to work with Google Home. Running the Google Home app on smartphone does not find a device. I don't know if it's the...
Apr 09, 2019Guru - Experienced User
If other devices are working with Orbi accept for the one device, you'll need to contact Google.
- Netduma-FraserApr 09, 2019NetDuma PartnerThe only thing I could recommend that may help if it was a router issue would be to disable QoS completely in Anti-Bufferbloat settings. Try that and see what happens.
- WacoJohnApr 09, 2019Luminary
Anti bufferbload is set to NEVER. Maybe Polk support is right. Thank you for the reply.
Thank you. I do not have an Orbi.
- FURRYe38Apr 09, 2019Guru - Experienced User
Opps type, sorry about that.
Do other devices worth with the XR router?
Other devices ... Uhm, .. well, various laptops, tablets, Smartphone, Alexa and Smart TV seem to. There is a Harmony Hub involved as well. I am not an expert in all this 'multiple device interoperability'.
- Netduma-FraserApr 09, 2019NetDuma PartnerSetting to Never is not the same as disabling fully in Anti-Bufferbloats 3 line option menu, do that and see if it works.
