WacoJohn
Apr 09, 2019Luminary
Polk Audio, Google Home, XR500
I have a Polk Audio MagniFi Mini Home Theater Sound Bar System which is supposed to work with Google Home. Running the Google Home app on smartphone does not find a device. I don't know if it's the...
Apr 09, 2019Guru - Experienced User
If other devices are working with Orbi accept for the one device, you'll need to contact Google.
Netduma-Fraser
Apr 09, 2019NetDuma Partner
The only thing I could recommend that may help if it was a router issue would be to disable QoS completely in Anti-Bufferbloat settings. Try that and see what happens.
- WacoJohnApr 09, 2019Luminary
Anti bufferbload is set to NEVER. Maybe Polk support is right. Thank you for the reply.
