WacoJohn
Apr 09, 2019Luminary
Polk Audio, Google Home, XR500
I have a Polk Audio MagniFi Mini Home Theater Sound Bar System which is supposed to work with Google Home. Running the Google Home app on smartphone does not find a device. I don't know if it's the...
Apr 09, 2019Guru - Experienced User
If other devices are working with Orbi accept for the one device, you'll need to contact Google.
Opps type, sorry about that.
Do other devices worth with the XR router?
- WacoJohnApr 09, 2019Luminary
Other devices ... Uhm, .. well, various laptops, tablets, Smartphone, Alexa and Smart TV seem to. There is a Harmony Hub involved as well. I am not an expert in all this 'multiple device interoperability'.
- Netduma-FraserApr 09, 2019NetDuma PartnerSetting to Never is not the same as disabling fully in Anti-Bufferbloats 3 line option menu, do that and see if it works.
Thank you again. Disabling QOS did not seem to help. Holding out for Google to uh ... 'fix it'.
