WacoJohn
Apr 09, 2019Luminary
Polk Audio, Google Home, XR500
I have a Polk Audio MagniFi Mini Home Theater Sound Bar System which is supposed to work with Google Home. Running the Google Home app on smartphone does not find a device. I don't know if it's the...
Apr 09, 2019Guru - Experienced User
Opps type, sorry about that.
Do other devices worth with the XR router?
WacoJohn
Other devices ... Uhm, .. well, various laptops, tablets, Smartphone, Alexa and Smart TV seem to. There is a Harmony Hub involved as well. I am not an expert in all this 'multiple device interoperability'.
- Netduma-FraserApr 09, 2019NetDuma PartnerSetting to Never is not the same as disabling fully in Anti-Bufferbloats 3 line option menu, do that and see if it works.
- WacoJohnApr 09, 2019Luminary
Thank you again. Disabling QOS did not seem to help. Holding out for Google to uh ... 'fix it'.
- Netduma_JackApr 10, 2019NetDuma Partner
Random idea, can you try enabling guest WiFi on the router and connecting to that? This worked before for someone having a problem with their NEST device
