68dodgeramman
Aug 24, 2020Aspirant
Poor Wifi signal and speeds with NightHawk XR500 and EX8000.
I have a 3,400 sq ft poured concrete home. The majority of living space is on the main floor, which is open concept. That's also where the extender is located on the west end of the house. The upstai...
Netduma-Fraser
Aug 25, 2020NetDuma Partner
First thing to check, what speeds do you get when you're directly connected via ethernet?
- 68dodgerammanAug 25, 2020Aspirant
Directly connected to the cable modem I get 200+. When I hook the router to the modem I'm back down to 12.
