68dodgeramman
Aug 24, 2020Aspirant
Poor Wifi signal and speeds with NightHawk XR500 and EX8000.
I have a 3,400 sq ft poured concrete home. The majority of living space is on the main floor, which is open concept. That's also where the extender is located on the west end of the house. The upstai...
Aug 25, 2020Guru - Experienced User
Concrete and steel will be most problematic for any wifi router.
Netduma-Fraser
Aug 26, 2020NetDuma Partner
Have you entered your correct speeds in bandwidth settings? If you disable QoS completely in Anti-BB options do you get full speed wired?
- 68dodgerammanAug 26, 2020Aspirant
Yes, I have full speed wired directly to the router now.
- Netduma-FraserAug 26, 2020NetDuma PartnerOkay so it was a settings issue, what QoS settings were you using previously?
- 68dodgerammanAug 27, 2020Aspirant
Anti-Bufferbloat Download 100.0% 226.2Mb
Upload 100.0% 12.0Mb
Bandwidth Allocation - Download 25% x 4 devicesUpload 25% x 4 devices
