Killhippie's avatar
Killhippie
Prodigy
Mar 02, 2018
Port 22 SSH closed, not stealthed.
Just loaded up the latest firmware for the XR500 2.2.0.4 and noticed that (yes I know shields up is not the greatest these days) but it came back saying all ports stealthed but that port 22 is closed. All other ports are stealthed. Anyone know whats going on there? I cant do a hard reset because the router has the password issue that the r7800 had where '\' symbol causes a 400 server error. Since I have a 63 character ASCII pasword I'm waiting for that to get fixed as im not changing my password to exclude that symbol on 12 devices. its bad enough typing it in the first time on a TV with a remote control!
 So back to the port 22 issue SSH login protocol, anyone else seeing this and any idea on a fix. Or is this a sit and wait for it to get fixed in a new update or is it even meant to be like this. My R7800 shows all steathed on latest firmware which also fixed the '\' password symbol issue.
  • I think that can all be resolved rather easily, it's with the Dev team now so will see when it can be done.
  • Hi Killhippie, have you spoken with Neil from Netgear? I have spoken to the developers they will double check and work on a fix if required. Don't worry its not a security risk!
    • Killhippie's avatar
      Killhippie
      Prodigy
      Yes I have. I was just throwing this out here to see if others had found this or knew a work around. Thanks for the assurance.  A stealthed port is only a closed port hidden by a black hole anyway and they know you’re there by the fact that your firewall doesn’t respond. I was just surprised to see port 22 showing as closed and not hidden.  Great router I have to say. Just a few teething problems,  nothing bad. II mean the R7800 has been out for over two years and that still got bugs. The only really big thing I noticed apart from the password symbol issue is the port numbering and I’m hoping that will be sorted with new firmware.
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        Totally understand, Neil has spoken with us so we're aware and will sort it out. Are you referring to the physical ports on the router being backwards essentially? If so Netgear are aware of that and can/will be fixed in an update as well.
