Jewelthief's avatar
Jewelthief
Port Forwarding Isn't Working
So I just recently switched from my old century link router to this new netgear router and I wanted to try and re-portfoward for some of my games. (note: on my old router, I port forwarded for my gam...
  • Jewelthief's avatar
    Jewelthief
    Aug 30, 2020
    After a sugar fuel'd rampage I figured out that the model of nokia, the G-240w-E has port forwarding options you can access through it. When you go into there you need to set your internal client to whatever other router your using. in my case the netgear r7000. and make sure mapping is enabled.
