Jewelthief
Aug 29, 2020Aspirant
Port Forwarding Isn't Working
So I just recently switched from my old century link router to this new netgear router and I wanted to try and re-portfoward for some of my games. (note: on my old router, I port forwarded for my gam...
- Aug 30, 2020
After a sugar fuel'd rampage I figured out that the model of nokia, the G-240w-E has port forwarding options you can access through it. When you go into there you need to set your internal client to whatever other router your using. in my case the netgear r7000. and make sure mapping is enabled.
Jewelthief
Almost forgot a important detail I think. The internet is being provided through a nokia wifi gateway 3. From what I know its just to get the internet from the street to the router. Im not sure if it would have anything to do with the port forwarding not working. Also, When I used my old router to get the port forwarding to work, That router was plugged in via ethernet. The new router, is not plugged in through ethernet. It is going through wifi to my pc. Im also not sure if that would make a difference but thought i should mension it.
Jewelthief
Aug 30, 2020Aspirant
