johngabraham
Jan 01, 2020Aspirant
Port forwarding not work
I have been trying for 2 days to figure out why my port forwarding isn't working. I've port forwarded many times before on previous routers but this one will not comply, unless I'm overlooking someth...
johngabraham
Jan 02, 2020Aspirant
I have a Netgear CM1200 modem with my XR500 connected directly to it. I'm not sure what an ISP hub is but the internet comes directly from the street into my own modem. I also don't know what DMZ is so I haven't touched any settings pertaining to it.
The ports I need to forward are 7777, 27015 (UDP) and 15000, according to this post. I forwarded all of them using TCP and UDP just to be safe.
Netduma-Fraser
Jan 02, 2020NetDuma Partner
Okay thanks for the information. First I'd check that this will work by putting the PC IP in the DMZ option in WAN Settings, then double check that site and see if it works. If it does then the port forward entries have been done incorrectly and we can figure out why that is.
- johngabrahamJan 02, 2020Aspirant
Ok I set my "Default DMZ Server" to my PC then checked the ports with the open port checker tool and it reports they're still closed. Is that what you meant for me to do?
- Netduma-FraserJan 02, 2020NetDuma PartnerYes that's right. Remove the port forwarding rules you've done as well and then try it again.
- johngabrahamJan 03, 2020Aspirant
Removed all port forwarding rules and still no dice.
