RNGeus000
Apr 28, 2019Aspirant
Port Forwarding
im trying to make a unturned server andi opened the port 27015 and when i laugh the server no one can join and when i check it it says its closed timed out but the server open to that port but no one...
schumaku
Apr 28, 2019Guru - Experienced User
Any other NAT device (ISP modem/router) in front of the R7000N?
Your ISP does assign a public IP address to the router WAN/Internet interface some Carrier-Grade NAT (CGN) as per RFC6598 or a private RFC1918 address?
Correct protocol forwarded - UDP or TCP?
Service up and running, no host based firewall prohibiting access?
- RNGeus000Apr 29, 2019AspirantI have only the one router and I have to use both protocols and I’ve did it both ways to see and no luck. And I turned off my firewall and didn’t work so I added a rule to me firewall and no luck so I don’t know. I just need to fix this Bc now when I check port 80 it’s closed too.
- schumakuApr 29, 2019Guru - Experienced User
Where to is the WAN/Internet port connected?
What is the first number of the WAN/Internet interface assigned IPv4 address (Advanced tab - Internet Port - IP Address)?
- RNGeus000Apr 30, 2019AspirantLike what do u mean all my Ethernet ports are plugged in and everything and I have charter As a isp.
