RNGeus000
Apr 28, 2019Aspirant
Port Forwarding
im trying to make a unturned server andi opened the port 27015 and when i laugh the server no one can join and when i check it it says its closed timed out but the server open to that port but no one...
RNGeus000
Apr 29, 2019Aspirant
I have only the one router and I have to use both protocols and I’ve did it both ways to see and no luck. And I turned off my firewall and didn’t work so I added a rule to me firewall and no luck so I don’t know. I just need to fix this Bc now when I check port 80 it’s closed too.
schumaku
Apr 29, 2019Guru - Experienced User
Where to is the WAN/Internet port connected?
What is the first number of the WAN/Internet interface assigned IPv4 address (Advanced tab - Internet Port - IP Address)?
- RNGeus000Apr 30, 2019AspirantLike what do u mean all my Ethernet ports are plugged in and everything and I have charter As a isp.
- schumakuApr 30, 2019Guru - Experienced User
Cable modem, or cable modem/router combo, ...? Another NAT router in front of the Nigthhawk will be cumbersome.
- RNGeus000Apr 30, 2019AspirantI have a cable modem and then a router. I have another router but it’s not plugged up should I just try that one instead
