RNGeus000
Apr 28, 2019Aspirant
Port Forwarding
im trying to make a unturned server andi opened the port 27015 and when i laugh the server no one can join and when i check it it says its closed timed out but the server open to that port but no one...
schumaku
Apr 29, 2019Guru - Experienced User
Where to is the WAN/Internet port connected?
What is the first number of the WAN/Internet interface assigned IPv4 address (Advanced tab - Internet Port - IP Address)?
RNGeus000
Apr 30, 2019Aspirant
Like what do u mean all my Ethernet ports are plugged in and everything and I have charter As a isp.
- schumakuApr 30, 2019Guru - Experienced User
Cable modem, or cable modem/router combo, ...? Another NAT router in front of the Nigthhawk will be cumbersome.
- RNGeus000Apr 30, 2019AspirantI have a cable modem and then a router. I have another router but it’s not plugged up should I just try that one instead
- schumakuMay 01, 2019Guru - Experienced User
The cable modem isn't acting as a NAT router, too? Many of these are ...
Again, compare the IPv4 address on your router Internet/WAN port (check the tiles on the [Advanced] view) against any "google what is my IP address" ... does iboth show the same?
