RNGeus000
Apr 27, 2019Aspirant
Port Forwarding
im trying to make a unturned server andi opened the port 27015 and when i laugh the server no one can join and when i check it it says its closed timed out but the server open to that port but no one...
RNGeus000
Apr 29, 2019Aspirant
Like what do u mean all my Ethernet ports are plugged in and everything and I have charter As a isp.
schumaku
Apr 30, 2019Guru - Experienced User
Cable modem, or cable modem/router combo, ...? Another NAT router in front of the Nigthhawk will be cumbersome.
- RNGeus000Apr 30, 2019AspirantI have a cable modem and then a router. I have another router but it’s not plugged up should I just try that one instead
- schumakuMay 01, 2019Guru - Experienced User
The cable modem isn't acting as a NAT router, too? Many of these are ...
Again, compare the IPv4 address on your router Internet/WAN port (check the tiles on the [Advanced] view) against any "google what is my IP address" ... does iboth show the same?
- RNGeus000May 04, 2019Aspirant
i looked on google my ip adress and looked on the netgear and they matched up. am i surpposed to have my router on ap mode or routher mode and my internet port page has only External Start Port and Internal Start Port and my local ip address so idk??
