RNGeus000
Apr 28, 2019Aspirant
Port Forwarding
im trying to make a unturned server andi opened the port 27015 and when i laugh the server no one can join and when i check it it says its closed timed out but the server open to that port but no one...
RNGeus000
May 05, 2019Aspirant
i looked on google my ip adress and looked on the netgear and they matched up. am i surpposed to have my router on ap mode or routher mode and my internet port page has only External Start Port and Internal Start Port and my local ip address so idk??
schumaku
May 05, 2019Guru - Experienced User
Great, so no provider Carrier Grade NAT involved
Router mode of course.
Use the same tart port for external and internal, the number of internal port(s) is derived from the external port range. If you want only one, put the same to start and end. and then select the LAN device where you want the forward to go to.
