gwager08's avatar
gwager08
Port Fowarding for XBox 1 X (XR500)
Does anyone know how the process of doing port forwarding on the Xbox One X, specifically for halo 5? Excuse my ignorance as I am not too familiar with advanced network setups.
    • gwager08's avatar
      gwager08
      Is port forwarding recommended? I am seeing conflicting information. The NAT on my Xbox is already open, so do I also have to manually open the ports in the router as well? Just confused as to what the best setting is.
      • FURRYe38's avatar
        Port Forward is not needed if you have uPnP enabled. If your getting OPEN NAT, then your ok.
        Also What is the Mfr and model# of the ISP modem the NG router is connected too? If this has a built in router this can cause connection problems.
