TheBigSleazy24
Dec 24, 2019Aspirant
Power and Internet lights not on but eth lights blinking
Set up my XR500 last night and everything was great. This morning no internet anywhere. Power cycled modem and reset with ISP. I looked at the router and all the lights were off, power, internet, WiFi...
Netduma-Fraser
Dec 24, 2019NetDuma Partner
Are you getting internet through the actual modem? Do the wired devices get any internet? Can you login to the interface using the LAN IP?
TheBigSleazy24
I have a wired connection to the router from my PC and I can get internet through my pc, but I can't access the routerlogin.net/com features or thru the dedicated ip address, it says i need to connect to the wifi network, but I shouldn't need to connect wirelessly if i'm connected thru a hard line?!
Thanks for your response.
