TheBigSleazy24
Dec 24, 2019Aspirant
Power and Internet lights not on but eth lights blinking
Set up my XR500 last night and everything was great. This morning no internet anywhere. Power cycled modem and reset with ISP. I looked at the router and all the lights were off, power, internet, WiFi...
TheBigSleazy24
I have a wired connection to the router from my PC and I can get internet through my pc, but I can't access the routerlogin.net/com features or thru the dedicated ip address, it says i need to connect to the wifi network, but I shouldn't need to connect wirelessly if i'm connected thru a hard line?!
Thanks for your response.
Netduma-Fraser
Dec 24, 2019NetDuma Partner
Try accessing directly by using these links http://routerlogin.net or http://192.168.1.1 (if it's the default IP). If not could you open a command prompt on your PC and type ipconfig and then press enter and post a screenshot of the results here please?
