SpicyGeek
Aug 02, 2025Follower
Power Interruption and 2.4GHz stops working
Every time I have a power interruption, the 2.4GHz on my XR1000v2 quits working. The 5GHz works fine though. The last time this happened, I talked with technical support on the phone and the only w...
CrimpOn
Aug 02, 2025Guru - Experienced User
Just curious. Does the same thing happen when the router is deliberately rebooted using the web interface?
