SpicyGeek
Aug 02, 2025Follower
Power Interruption and 2.4GHz stops working
Every time I have a power interruption, the 2.4GHz on my XR1000v2 quits working. The 5GHz works fine though. The last time this happened, I talked with technical support on the phone and the only w...
Netduma-Fraser
Aug 03, 2025NetDuma Partner
Make all your changes and then reboot the router from the interface, this acts as a hard save and so should then in theory prevent it happening when power is lost
