TimeUnlimited
Feb 10, 2020Aspirant
power light on AC1750 R6400v2 Blinking
Had the router for about a month or two not too long and one day I was updating through the app and my friend turned off the router thinking the internet was down when he turned it back on the power ...
TimeUnlimited
Feb 11, 2020Aspirant
I meant TFTPD64 which is what i tried to use an alternative for TFTP because every time i tried it never worked always said unable to get response from server but i followed the method you suggested using nrmpflash and what i got from that was bailing out no response after 60 seconds not exactly sure where to go from here.
Feb 11, 2020Guru - Experienced User
if you've tried tftp and nmrpflash, you might be out of options.
If you're still within warranty, you can try that option. The prior post went over doing that.
