HELPAB1992
Feb 05, 2025Aspirant
PPPoE - Set up Nighthawk
Good Morning! I am trying to set up my XR500 on PPPoE on a new internet provider. The old one worked fine but I cannot seem to get the internet through this one. I have the PPPoE username and...
Feb 05, 2025Guru - Experienced User
Might check with the ISP to ensure all PPPoE configurations and input is correct.
- HELPAB1992Feb 07, 2025AspirantThank you for this - I have checked and tried but I am a novice when it comes to this so I am unsure if I am not doing something pretty simply which is refraining the internet pass thru as light is still amber. If anyone if able to support via phone that would be amazing?
- Netduma-FraserFeb 07, 2025NetDuma PartnerIf you want phone support you'll have to go through the support page and go from there. It's not something I can provide and it will cost you potentially.
As above, what is the model of the modem/router the XR is connected to? Do you definitely require PPPoE with this new connection?
