elevateX
May 30, 2018Follower
Printer Not showing up in Device Manager on XR500
Hi,
I have a Samsung 680ND printer connected to the XR500 via ethernet. The printer does not show up in the Device Manager. The XR500 is set to "Use the Router as a DHCP server". The Samsung...
Netduma-Fraser
May 31, 2018NetDuma Partner
Hi elevateX, the printer may appear under the device manager as an unnamed device if the router hasn't recognised the printer. Ensure you know the printers IP address and then try to match it with any of the unnamed devices. Then could can rename it and assign it the type of printer.
