3ijtKwij's avatar
3ijtKwij
Initiate
Feb 12, 2019
Prioritize SLOBS and League XR500
So I received my Nighthawk XR500 today and I tried to add both League Of Legends as well as Streamlabs OBS as prioritized apps on my Desktop.
Adding League Of Legends didn't seem to be a problem, just selecting my PC and under basic I'll find League Of Legends. But when I try to add the port for Streamlabs OBS (which seems to be 1935 for TCP, when I go to add device, select my PC and under advanced leave the source port alone and enter 1935 for both start end end in destination ports, then selecting TCP once I click done I get "Unable to install because streams overlap."
How can I get prioritization for both League Of Legends as well as streaming this game to Twitch with Streamlabs OBS?
Thanks in advance!
  • I'd look up what ports both applications use then remove the LoL rule and add a manual one which encompasses the ports for both instead. I would however highly recommend you don't prioritize something that will be streaming as it's only mean for low bandwidth applications
