KAustralia
Oct 09, 2023Follower
Pro Gaming XR1000 - Can't connect to NBN home - says no internet connection
Hi. We are not getting internet to the router when we connect to the NBN home box. Our ISP said it should be compatible, We have tried Netgear support who after 2 hours trying to help told us the uni...
Oct 10, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Be sure there are no specific ISP configurations needed. Something to ask the ISP about.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
