digu
Dec 06, 2022Follower
Pro gaming xr500
HI, I bought the pro gaming xr500 and I would like to know why my xbox got nat restricted and how to solve it?. Note: My xbox is connected to the old router because in netgear it changes ip.
- Dec 07, 2022
I'd suggest connecting the Xbox to the XR500, otherwise you won't be able to take advantage of all the benefits of DumaOS and the XR500.
You'd expect it to change the Xbox's IP, as it's a different router. This shouldn't cause you any problems though.
Once you've done that, I'd also suggest going to the DumaOS interface by going to 192.168.1.1 in the web browser of a device connected to the XR. Then, go to System Information and copy the XRs WAN IP. Go to your ISP router/modems interface and put this IP in the DMZ. That should resolve the NAT problems.
Kitsap
Dec 06, 2022Master
digu wrote:HI, I bought the pro gaming xr500 and I would like to know why my xbox got nat restricted and how to solve it?. Note: My xbox is connected to the old router because in netgear it changes ip.
There is a separate community for Nighthawk Pro Gaming Routers. You might get more and better answers posting your question there. Here is the link: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/bd-p/en-home-nighthawk-pro-gaming-routers
