digu
Apr 07, 2023Follower
Pro gaming xr500
I bought a Progaming xr500, my Xbox nat is closed, the internet router company does not provide settings in the router's DMZ. What do I do?
- Apr 07, 2023If you answer the above we'll be able to help better, we also have our own guide on opening your NAT https://support.netduma.com/en/support/solutions/articles/16000076587-dumaos-optimal-settings-guide-open-nat
Apr 07, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Something to contact MS about:
https://support.xbox.com/en-US/help/hardware-network/connect-network/xbox-one-nat-error/
https://www.windowscentral.com/xbox-port-forwarding
https://www.techsolutions.support.com/how-to/how-to-change-nat-type-on-xbox-one-12472
