Salva2022
Jul 08, 2022Star
Probelm with XR500 and IPTV
Hello, there, I`ve a problem with my router. I have the neweset firmware installed. The problem is, that it takes sometimes 10 seconds to open the IPTV channel. If the Set-Top-Box is connected with m...
Netduma-Fraser
Jul 08, 2022NetDuma Partner
Disable QoS fully, does it open quicker then?
- Salva2022Jul 08, 2022StarHello, I will test it! Thank you.
- Salva2022Jul 08, 2022StarHi, I have QoS deactivated fully - it seems that the problem is solved!! Thank you.
- Salva2022Jul 08, 2022StarHi, sorry, after a restart the problem is back again.
- Netduma-FraserJul 08, 2022NetDuma PartnerIs that with QoS still disabled? Could you toggle IGMP Proxying and SIP ALG in WAN Settings and try again please?
