Salva2022
Jul 08, 2022Star
Probelm with XR500 and IPTV
Hello, there, I`ve a problem with my router. I have the neweset firmware installed. The problem is, that it takes sometimes 10 seconds to open the IPTV channel. If the Set-Top-Box is connected with m...
Netduma-Fraser
Jul 08, 2022NetDuma Partner
Disable QoS fully, does it open quicker then?
Salva2022
Jul 08, 2022Star
Hello, I will test it! Thank you.
