petterpan
Feb 19, 2021Aspirant
Problem connecting to wifi with the newest firmware V1.0.1.38 on xr700
Having problem connecting my Oneplus 8 Pro to the wifi after updating the xr700 to firmware version 1.0.1.38 Its trying to obtain ip adress but is failing. Only way to connect is to manually inp...
petterpan
Also my xiamoi security cam is not able to connect to wifi anymore
Netduma-Liam
Feb 19, 2021NetDuma Partner
Did you perform a factory reset after the upgrade? This is often required as it clears anything low-level left after the old version
- petterpanFeb 19, 2021Aspirant
Yes, I did a factory reset, also I found out that the issue is not reletadet to only wifi becouse my wired lg smart tv is having the same problem.
I get the error message "DNS not found"
But when i downgrade firmware its working.
So in short Oneplus 8 pro = not working (can maually input dns server and then its working)
xiamoi security cam = not workingLg smart tv(wired) = not working
Win 10 computer = working
Arlo = working
Have tried factory reset, hard reset, restart of both fiber media converter and xr700 router.
- Netduma-FraserFeb 19, 2021NetDuma PartnerAre you using Smart Connect for WiFi? Some devices have trouble connecting with that method. Have you set custom DNS?
- petterpanFeb 19, 2021AspirantSeems like somehow the problem have fixed itselfđ
- Netduma-FraserFeb 19, 2021NetDuma PartnerThat's great to hear, thanks for the update!
