petterpan
Feb 19, 2021Aspirant
Problem connecting to wifi with the newest firmware V1.0.1.38 on xr700
Having problem connecting my Oneplus 8 Pro to the wifi after updating the xr700 to firmware version 1.0.1.38 Its trying to obtain ip adress but is failing. Only way to connect is to manually inp...
Netduma-Liam
Feb 19, 2021NetDuma Partner
Did you perform a factory reset after the upgrade? This is often required as it clears anything low-level left after the old version
petterpan
Yes, I did a factory reset, also I found out that the issue is not reletadet to only wifi becouse my wired lg smart tv is having the same problem.
I get the error message "DNS not found"
But when i downgrade firmware its working.
So in short Oneplus 8 pro = not working (can maually input dns server and then its working)
xiamoi security cam = not working
Lg smart tv(wired) = not working
Win 10 computer = working
Arlo = working
Have tried factory reset, hard reset, restart of both fiber media converter and xr700 router.
- Netduma-FraserFeb 19, 2021NetDuma PartnerAre you using Smart Connect for WiFi? Some devices have trouble connecting with that method. Have you set custom DNS?
- petterpanFeb 19, 2021AspirantSeems like somehow the problem have fixed itselfđ
- Netduma-FraserFeb 19, 2021NetDuma PartnerThat's great to hear, thanks for the update!
- TeddyBearIlluApr 05, 2021Aspirant
Netgear Nighthawk XR700 Gaming Router AD7200 Performance WiFi (-100EUS). Firmware V1.01.38.
My new router is continuously dropping my connection via WiFi and LAN.
Please, provide immediate help and support to solve this problem.
Tested and Verified with other router without any problems. Paid 500⏠one would expect to get a high quality product that will work in reliable manner. How to trust to company asks high prices you would expect at least the basic functional requirements are met. Maybe customer satisfaction has got a new meaning..
