petterpan
Feb 19, 2021Aspirant
Problem connecting to wifi with the newest firmware V1.0.1.38 on xr700
Having problem connecting my Oneplus 8 Pro to the wifi after updating the xr700 to firmware version 1.0.1.38 Its trying to obtain ip adress but is failing. Only way to connect is to manually inp...
TeddyBearIllu
Apr 06, 2021Aspirant
hi,
the connection comes back up eventually itself. No need to reboot the router. Please, see enclosed photo for model (Netgear XR700-100EUS). During my important online customer meetings, the connection is continuously dropping off. Hopefully you are able to give help and support with my problem?!
Netduma-Fraser
Apr 06, 2021NetDuma Partner
Liam was asking what the model is of the modem/router the XR700 is connected to. Give your devices (start with the most important) reserved IP address in LAN Settings and see if they sustain a connection
