jebrown1979
Apr 30, 2020Guide
problem might be sorted
ok so after hours of testing i think i might have sortd my problem while playing pes2020 on my 4k tv downstairs on wifi game played so so smooth but when i put it upstairs game feels terrible i tried...
Netduma-Fraser
Apr 30, 2020NetDuma Partner
Are you playing on WiFi upstairs? If so it sounds like upstairs there is more WiFi congestion. The fact it differed so much just by changing rooms doesn't indicate a settings issue but as long as you're having a good experience that is all that matters.
- jebrown1979Apr 30, 2020GuideNo wired upstairs always wired just tried WiFi downstairs just to see and yeah it seems weird I just didn’t know what to do to fix it because the WiFi worked much faster than my wired connection always has just wish I knew what the problem is/was like I say not an expert just don’t know how to pinpoint the problem
- Netduma-FraserApr 30, 2020NetDuma PartnerIt could be the cable then in that case, I would try doing a ping when connected via the ethernet cable and then another when connected to the WiFi and see if there is a difference.
- jebrown1979Apr 30, 2020GuideHahaha and I just bought some cat7 cables should have stuck to the cat5e patch cables that came with the router and from my isp but ok will do a ping test and tell you the results later
