jebrown1979
Apr 30, 2020Guide
problem might be sorted
ok so after hours of testing i think i might have sortd my problem while playing pes2020 on my 4k tv downstairs on wifi game played so so smooth but when i put it upstairs game feels terrible i tried...
jebrown1979
Apr 30, 2020Guide
No wired upstairs always wired just tried WiFi downstairs just to see and yeah it seems weird I just didn’t know what to do to fix it because the WiFi worked much faster than my wired connection always has just wish I knew what the problem is/was like I say not an expert just don’t know how to pinpoint the problem
Netduma-Fraser
Apr 30, 2020NetDuma Partner
It could be the cable then in that case, I would try doing a ping when connected via the ethernet cable and then another when connected to the WiFi and see if there is a difference.
- jebrown1979Apr 30, 2020GuideHahaha and I just bought some cat7 cables should have stuck to the cat5e patch cables that came with the router and from my isp but ok will do a ping test and tell you the results later
- jebrown1979Apr 30, 2020GuideAlso are you asking me to a ping test through the PS4 web browser
- Netduma-FraserApr 30, 2020NetDuma PartnerPreferably use a PC for both tests as it will be easier to do. Also switch back to the other cables and test as well to see if there is a difference.
