jebrown1979
Apr 30, 2020Guide
problem might be sorted
ok so after hours of testing i think i might have sortd my problem while playing pes2020 on my 4k tv downstairs on wifi game played so so smooth but when i put it upstairs game feels terrible i tried...
Netduma-Fraser
Apr 30, 2020NetDuma Partner
It could be the cable then in that case, I would try doing a ping when connected via the ethernet cable and then another when connected to the WiFi and see if there is a difference.
jebrown1979
Apr 30, 2020Guide
Hahaha and I just bought some cat7 cables should have stuck to the cat5e patch cables that came with the router and from my isp but ok will do a ping test and tell you the results later
- jebrown1979Apr 30, 2020GuideAlso are you asking me to a ping test through the PS4 web browser
- Netduma-FraserApr 30, 2020NetDuma PartnerPreferably use a PC for both tests as it will be easier to do. Also switch back to the other cables and test as well to see if there is a difference.
also is it best to use a patch cable from modem to router and same from router to ps4 because they all say patch cable apart from them cat 7 ones i bought
