victorjohn9211's avatar
Oct 22, 2019
Problem with NetGear 8-Port Gigabit Ethernet Switch?
Hi,   I am trying to connect NetGear 8-Port Gigabit Ethernet Switch with my computer but its not showing any internet sign on my desktop. I have installed its wires and softwares too.   Thanks ...
  • schumaku's avatar
    Oct 22, 2019
    The GS608v3 is an unmanaged switch, it does not come with any software for that very reason.
    Just a computer and a switch connected does not make an Internet access. Should the switch be connected eg. to a cable modem (not a modem/router combo) [or probably a downunder NBN outlet] you need to be ware that these typically only assigns one public IP address - and this address is intended to run a NAT/WiFi router.
    What hits my eyes is that the price quoted for this very basic switch is completely beyond - the 234 AUD (or about 160 USD) should buy you four or five units.
