Panicwar83
Mar 28, 2022Apprentice
Problema visualizzazione Ping Heatmap e Benchmark di connessione su XR500
 Salve. Ho un problema per quanto riguarda la funzionalità Ping Heatmap e Benchmark di connessione .  Praticamente utilizzando Ping Heatmap non mi fa vedere nessun server disponibile e cliccando su Pr...
- Apr 01, 2022È probabile che sia un bug che dovremo correggere, quindi per il momento sarebbe la soluzione alternativa
Mar 28, 2022Guru - Experienced User
In inglese per favore
Your ISP Modem already has a built in router and wifi. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
