LilsTheGOAT
Apr 24, 2019Guide
Problems setting up, turning off?
Hey guys!
So I bought a the NetGear XR300 and DM200 Modem to replace my Sky modem/router. Following the setup process I can't get the router to stay on to complete setup.
Power both on, g...
LilsTheGOAT
Apr 24, 2019Guide
Cheers guys!
- LilsTheGOATApr 25, 2019Guide
So the new one works, but no I have set-up problems.
I completed the set-up wizard and it found my connection. The speed test came back with nothing.
After completing the set-up I had no internet access on my computer. Every time I went to access a website it sent me back to the router login.I did try using the Mac of my old router to no avail. I also reset the modem and router a few times.
What do I need to do?
- Netduma-FraserApr 25, 2019NetDuma PartnerThat sounds like you haven't actually completed the setup wizard, did you get past the part where it asks you to register the product on the Netgear site?
Interesting, no it didn't.
On a side note, I have found that I can't connect with the modem only. So could it be the modem needs setting up?
